Dodge Challenger Forum for the 2008+ Challenger. This includes the SE, SXT, R/T, Shaker, Scat Pack, SRT and Hellcat models.
2014 challenger sxt-Sway Bar shift
Old Jul 2, 2023 | 08:28 PM
@CarG1rl@'s Avatar
@CarG1rl@
Default 2014 challenger sxt-Sway Bar shift
So I had little disagreement with a ditch while in the mountains a couple weeks ago....noticed my bushings slipped out and decided to replace them. While under the car I noticed my sway bar has shifted just far enough that the notch on the passenger side sits center where the bushings go. Any advise on how to shift it back?
any ideas where I can pick up a locking lug key would be Fab as well (been to the local dealer, tire store and several auto parts stores
Thank you
Old Jul 2, 2023 | 09:31 PM
If you have both the sway bar mounts loose, should be able to just push the bar over to where you want it.
If you can't find the correct key for your locking lug nuts, most tire stores will have sockets to remove them..... of course, that only works once.... so, new lugs/locks will be in order.
Old Jul 3, 2023 | 11:58 PM
@CarG1rl@'s Avatar
@CarG1rl@
I ended up ordering the "correct" OEM part (lug key)As long as it works I will definitely try loosening. Thank for the response
