Battery Tender vs. Disconnect
Somewhere I had heard that battery tenders are not good for your battery's life. Has anyone heard this? If you're out of town for, say, several weeks would it be better just to disconnect the battery?
Thanks
Thanks
Thanks! Reason I asked is that I went through several batteries years ago on my RT because I wasn't starting them up regularly. Two AAA battery guys told me to run the cars at least once a week. My current batteries (RT and Hellcat) should be in very good condition.
If buying a tender make sure you get what is called a float or maintainer charger. Some low level trickle chargers feed all the time and can be hard on a battery, but a float type charger will charge on and off as needed. Like mentioned, unless you have known issue with loosing charge I would not be to concerned. However there is zero harm running a tender. I buy the 15$ harbor freight ones, they work great, I have 2 or 3 of them.
Thanks, Dodgetruck2. Does it matter where you attach the tender, i.e., hood or trunk? I have a convenient AC outlet at the rear of my garage that would be ideal for trunk access.
Is this the Harbor Freight product? https://www.harborfreight.com/12v-de...ger-62813.html
Trending Topics
Tenders and maintainers don't generally cause trouble but imported Chinesium units have poor quality control. You want a float charger attached to the battery at the terminals. Depending on where the battery is located, that's where you run the power line. The trunk can be problematic as the lid may damage the wires.
A float charger won't hurt a thing. Just use the end that bolts to the terminals and leave the other end of the charge cord in your tool box. Unplug it when you want to drive the car and plug it back in when you plan to park it for a while. This way your radio and other systems keep their memory.
Battery Tender is one product but I've seen cheap knock offs that LOOK like them but aren't quite right on the packaging. Personally, I use equipment made by Schumacher. I have several light duty chargers and they have always worked fine for me.
