Sponsored by:
Sponsored by: CARiD
front end popping noise
Old Jul 19, 2007 | 05:40 PM
BigBananna3796of4000's Avatar
Default front end popping noise
I have noticed a popping noise from my front end when I am turning the wheel hard one way.
I get get the problem to be consistant but it happens enough that it bugs me.
any ideas?
Old Jul 20, 2007 | 03:22 AM
blueovalfan's Avatar
blueovalfan
Default RE: front end popping noise
Whoo! Sounds like the same thing my ride does once in a while. However, I haven't crawled around undernethyet to look around.
Old Jul 20, 2007 | 08:46 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I'll make the"Mr point out the obvious a lot" comment. Sounds like the suspension
Sway bar bushings... tie rods
Old Jul 20, 2007 | 09:28 AM
Makes sense.
I am going to put new Mopar sways and coil overs soon. It should fix it up.
Old Jul 20, 2007 | 11:02 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Oh yea! Your going to be all up in there and should get a good look at everything.
Your going to like it a lot.
Old Jul 20, 2007 | 11:42 PM
mnboy's Avatar
mnboy
If you were a Soprano, I'd say check the trunk for noises...
But the front and it's a fairly new car, something doesn't seem right. Make sure your front wheel lugs are tight, or is it a loose wheel cap, or did your wife/girlfriend/boyfriend/significant other/dad/son/daughter/best friend/or you hit a curb and forget to tell you/you forgot??
I would find it BEFORE you do any suspension work. Best to know what it is.
MN
