Sponsored by:
Sponsored by: CARiD
Buying a key?
Old Aug 16, 2007 | 12:57 PM
Bryantlozano's Avatar
Bryantlozano
Default Buying a key?
I just bought a Charger 07 and I lost one of my keys and i cant seem to find it. Were can I buy one since it has the alarm control included? I went to the dealer and they didnt have one but could order it for me for $500.00 wich is too much for a key. any advise.
Old Aug 16, 2007 | 01:23 PM
goldsmi's Avatar
goldsmi
Default RE: Buying a key?
http://cgi.ebay.com/ebaymotors/2006-...mZ120150277633
Old Aug 16, 2007 | 02:16 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Man 500, thats rape!
Here aredirections for programming a new key. This is supposed to work on domestic (US) vehicles, non domestics have to have the dealer program new keys.
1. Insert one of two programmed keys and turn ignition switch to on.
2. After ignition has been set to "on" for over 3 seconds but not more than 15 seconds turn the ignition back to "off".
3. With in 15 seconds insert the second key and turn the ignition switch to "on".
4. About 10 seconds later the security indicator in the instrument cluster will start flashing.
5. With in 60 seconds replace the second key in the ignition with the new key. Turn the ignition switch to "on" using the new key.
6. After about 10 seconds the security indicator will stay on for about 3 seconds and then turn off to indicate that the key was successfully programmed. Turn the ignition to "off" and you can now use the new key with the vehicle.
Old Aug 16, 2007 | 03:55 PM
Bryantlozano
ThanksGoldsmi and MangoInTx, I really apreciate it. I already ordered the key from ebay and it was 120.00 total which saved me 380.00 thanks. and as soon as i recieve it with in the next 3 bussiness days all i have to do is take it to get cut like the original and i can do the programing at home with saved me 95.00 form the dealer. Thanks a lot
Old Aug 16, 2007 | 08:48 PM
goldsmi's Avatar
goldsmi
Remember - you need TWO currently functional keys in order to program the new ones once they are cut.
If you have only one, you'll have to visit the dealer and have the service department program one of the new ones.
AL
Old Aug 16, 2007 | 09:17 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Believe it or not some have programed a key with only one original key. It may beone of them freak things but it may work.
In step 3 they used the same key as step 1.
Personally I haven't experience programming a key. It's probably a good idea to get one from e-bay and program it whiletwo good keys are available and stash the extra for the day one may be lost.
Old Aug 16, 2007 | 09:43 PM
goldsmi's Avatar
goldsmi
Exactly!
Old Aug 25, 2007 | 03:33 AM
pebcak2000's Avatar
pebcak2000
I only got one key when I purchased my '07 RT new??? Should I have gotten two?
Old Aug 25, 2007 | 10:25 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I would think this thread should be enough to make one ask for a second and work a third into the mix if the cost is right.
Old Aug 26, 2007 | 04:04 AM
pebcak2000's Avatar
pebcak2000
I will rephrase my question...as part of the purchase....should the dealer have provided me with two keys? Or am I old school in thinking that a new car should come with two keys?
