Sponsored by:
Sponsored by: CARiD
Maintenance Questions
Old Sep 15, 2007 | 12:17 AM
pebcak2000's Avatar
pebcak2000
Default Maintenance Questions
I was and still planning on following maintenance schedula "A" in the owener's manual. However I noticed on my dealerhip's service department website (I do most of my own maintenance and use a non dealer mechanic for the rest) the services suggested from the dealer include the following:
1. Throttle Chamber Service - I have an idea what this is but do not see anything in the manual even close to this. I know on carb and throttle body systems you take the can of carb cleaner and and clean eveything up. The dealer was charging a hefty fee for this service.
2. Automatic Transmissionflush at 30,000 miles - The owner's manul states that this should be done at 120,000 miles.....this seems like a loooong time to me. Also, what is involved in flushing the tranny? Is this something that I can do myself?
3. Brake fluid flush - Again, this is something not mentioned in the owner's manual. When if ever should the brake fluid be flushed?
Other maintenance questions I have:
1. Air Conditioning Filter - I am assuming this is the HEPPA filter for the cabin area. Where can one find an aftermarket filter and how much are they?
2. Fuel Filter - when should they be replaced?
3. Fuel Injectors - when should they be replaced or cleaned. If clean, how often and how?
4. Power Steering Flush - is this really needed and if yes, how often?
I think this all for now anyways
Thanks
Old Sep 15, 2007 | 09:07 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Maintenance Questions
1. Not sure beyond a general cleaning.
2. Dealer service since we don't have a dip stick <= rip off
3. Not sure.
Other
1. Cabin filter - See this thread: https://dodgeforum.com/m_664633/tm.htm
2. Hopefully never, I hear it's on top of the tank which is difficult to drop.
3. Not sure.
4. Not sure.
Hopefully someone can fill in the blanks.
Old Sep 15, 2007 | 10:45 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I found a detailed maintenance schedule in the service manual but can't get it to my web site. As soon as I can upload it I will post it up.
Old Sep 15, 2007 | 08:29 PM
pebcak2000's Avatar
pebcak2000
Thanks for the info. Just want to make sure our babies (my charger and wifes magnum) are taken care of
Old Sep 16, 2007 | 12:00 AM
SrtHemi's Avatar
SrtHemi
Ive wondered about this one:
" 2. Dealer service since we don't have a dip stick <= rip off"
There is no way to get around that? I mean lord forbid if it ever leaks and you need to add any?
Old Sep 18, 2007 | 10:20 AM
mnboy's Avatar
mnboy
My suggestion is this: When it leaks, worry about it then...
MN
Old Sep 29, 2007 | 09:18 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Finally got it uploaded.
http://home.tx.rr.com/rgd/MaintenanceSchedule.pdf
Old Sep 29, 2007 | 08:42 PM
pebcak2000's Avatar
pebcak2000
Thanks for the upload....that looks like the same schedule in my owners manual.
here is the rough schedule I adopted for my Charger & the Wife's Magnum:
Interval Maintenance
Oil Change - Mobil 1 Synthetic 7 qts
3000 miles
Oil Filter Change - K&N HP2004
3000 miles
Rotate Tires
6000 miles
Replace air conditioning filter - NAPA Part #4909
12000 miles
Inspect Brakes / Rotors
12000 miles
Replace the air cleaner filter
15000 miles
Replace Fuel Filter
20000 miles
Flush Engine Coolant
30000 Miles
Fuel Injection / Throttle Body Service
30000 Miles
Flush Transmission
30000 miles
30000 miles
Check / Replace PCV Vavle
30000 miles
Replace Spark Plugs - Champion Platinum 3570
30000 Miles
Ignition System Innspection
30000 Miles
Rear Axle Fluid Change
48000 Miles
Wheel Bearing Serice
60000 Miles
Did I miss anything?
Old Sep 29, 2007 | 10:05 PM
edge56's Avatar
edge56
How do you know if your car is supposed to be equipped with the AC filter under the hood? I have the Daytona Charger R/T and there is nothing in the compartment under the hood
Old Sep 30, 2007 | 11:44 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I'm not sure which pkg had them and which did not but you did the right thing and just checked to see.
