Sponsored by:
Sponsored by: CARiD
heat/A/C illumination out
Old Oct 12, 2007 | 12:11 PM
firecharger's Avatar
firecharger
Default heat/A/C illumination out
does anyone know why my illumination would not work on my heat/A/C controls? i checked the fuse which i believe was #14 in the rear and it was fine. Is there a bulb? If so how do i remove the dash panel to get to it? thanks, Mike NW Indiana
Old Oct 12, 2007 | 04:33 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: heat/A/C illumination out
I'm not sure if fuse 14 in the rear is correct, I think that may be the Sentry Key/Remote Keyless Entry/Cluster.
I haven't found a fuse that is marked for the A/C... yet. [&:]
Old Oct 15, 2007 | 08:32 PM
firecharger
im still looking, the radio cluster works, but no heat/ a/c cluster lights which makes me believe it might actually be a bulb
Old Oct 15, 2007 | 08:50 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Hum... the dash lights are leds not really bulbs I wonder what the others are?
Old Oct 15, 2007 | 10:01 PM
Dodge Tech's Avatar
Dodge Tech
need a new HVAC control head
Old Oct 16, 2007 | 11:19 AM
firecharger
thanks tech,do you thinkthis be something covered under warranty? i have a 06 with 20,000.
Old Oct 16, 2007 | 12:13 PM
Dodge Tech's Avatar
Dodge Tech
yep
