Sponsored by:
Sponsored by: CARiD
A/C compressor
Old Oct 29, 2007 | 11:00 PM
3.5sxt's Avatar
3.5sxt
Junior Member
Default A/C compressor
Hello - Can anyone tell me if the A/C compressor is supposed to run / cycle on andoff when control is set to 'floor' position? It operates normally otherwise, i.e., on defrost, etc. It does not run on any of the 'vent' postions or 'mid' postions, but does cycle on and off in 'floor' position. The htr / AC control unit was just changed because the lamps were out. I can't imagine why they'd program that into the system...it can't help gas mileage to have that running all winterand it's unnecessary to heat the car. Thanks for any help.
Old Oct 30, 2007 | 01:57 AM
Dodge Tech's Avatar
Dodge Tech
Default RE: A/C compressor
yes all chrysler cars and trucks do this the defrost will turn on the compressor to remove the water from the air.
Old Oct 30, 2007 | 09:02 AM
3.5sxt's Avatar
3.5sxt
Junior Member
Hi again - thanks for reply...the compressor is supposed to be on in 'defrost' but when the control is set to 'floor' position, like just regular winter heat, I've never seen a compressor run. I've also looked a couple of other cars lately that did not run in 'floor' position.
