Sponsored by:
Sponsored by: CARiD
Charger Steering problem
Old Apr 20, 2008 | 01:04 PM
mauls's Avatar
mauls
Default Charger Steering problem
Info: 2006 Dodge Charger R/T 48,800 miles
Whenever I go to turn left or right at slow speed it makes a loud "Whining" noise. Sounds like chewbaca off of star wars.
/also the power steering cuts in and out at slow speeds.
Checked the fluids, they looked a little dirty but they were at the right leve., I'm thinking it's the power steering pump.
Any body have any insight on this? If it's the pump how much do those usually cost to get fixed.
Thanks in advance
Old Apr 22, 2008 | 07:32 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Default RE: Charger Steering problem
It could be several things...tie rod, control arm,steering rack, sway bar bushings, tension struts maybe a combo of things.
Have you changed tire sizes?
Old Apr 22, 2008 | 10:28 AM
74scamp's Avatar
74scamp
You might try jacking both front tires off the ground, and, with the help of a friend, carefully start it up and carefully turn the steering wheel and see if you can duplicate the sound. This might tell you if its the pump or perhaps part of the linkages. Not real sure what you might find, but might be a place to start.
Dave
Old Apr 28, 2008 | 12:17 AM
mauls's Avatar
mauls
Well I hope it's nothing major, I've been driving it since it happened. It just makes the annoying "whining" noise when I turn. It happened when I was doing a little "hot rodding" and was ripping around a turn and something popped.
Old May 15, 2008 | 06:14 PM
BigJim191's Avatar
BigJim191
I have 80 thousand km on my charger and the inner tie rods are worn out and wheel bearings need replacing. I guess nothing lasts long with these new cars...it seems the parts wear out faster then they use too.
