Sponsored by:
Sponsored by: CARiD
malfunction indicator light
Old Aug 11, 2008 | 07:16 PM
hsahagun's Avatar
hsahagun
Junior Member
Default malfunction indicator light
I have a 2006 dodge charger my malfunction indicator light is staying on. any ideas what it means?
Old Aug 11, 2008 | 07:42 PM
charginscott's Avatar
charginscott
Your manaul should tell you how the do the key dance to figure out what the code is. Or you could go to Autozone and they will pull the code(s) and tell you what they are.
Does your car have the EVIC on it? If so it can tell you also.
Old Aug 11, 2008 | 08:04 PM
hsahagun's Avatar
hsahagun
Junior Member
did the key dance everything worked and got a message saying DONE no codes.
Old Aug 12, 2008 | 09:15 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Interesting because the check engine light (CEL) is an indicator that there is a code.
Old Aug 12, 2008 | 12:49 PM
charginscott
Try taking it to AZ and see if they can get the codes
Old Aug 12, 2008 | 04:22 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Go with Scott's suggestion and take it to your favorite auto parts store. They should have a code reader they can hook you up with, it shouldn’t take but a few minutes and it’s free.
Old Aug 15, 2008 | 10:42 PM
dodgeboy64's Avatar
dodgeboy64
Default Low tire pressure warning
Just a guess, it isn't the low tire pressure warning light?
