Sponsored by:
Sponsored by: CARiD
charger rt brakes
Old Dec 18, 2008 | 10:36 AM
uaedurango's Avatar
uaedurango
Default charger rt brakes
Does anyone have any information on good upgrades to the charger rt 2006 brakes?
I was at the dealer the other day asking if the srt8 brakes could be put on and he did not recommend it saying that several customers did this, as well as outside brakes and there was a problem due to caliper piston differences (2 vs. 4 or even 6) and that the lines were not large enough even if the master cylinder was changed. lastly, they said the steering knuckles would need to be changed.
For me, brakes were always one of the weak spots on the car. Even though I have had the mopar performance parts added, brakes are still weak (high speed braking).
Any help or experience greatly appreciated.
I have 20" wheels on it, so larger caliper clearance is not an issue.
Old Dec 18, 2008 | 11:48 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
SRT8 brakes can be put on an R/T but you also have to put other SRT8 suspension parts on the R/T. Here's a shopping list: Front Calipers/Rotors/Spindles/Hubs, Rear Stub Axles/Hubs/Rotors/Calipers.
I have a local friend that has done this to his 06 GoManGo.
If you can find used SRT8 parts it will cost around 2K, that's for the parts. If you go with new parts, DCX SRT8 parts or after market, it's going to cost some major Hemi Bucks (4-5K <= low-ball).
Good luck on your quest!
Old Dec 18, 2008 | 01:40 PM
uaedurango's Avatar
uaedurango
ok, so skip for now the srt8 avenue.
what may be a good way to get performance brakes up on the rt as it is?
any examples? who makes parts?
what is the existing caliper on the rt, 4 piston?
Old Dec 18, 2008 | 02:25 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
The R/T has twin-piston calipers in front and single-piston calipers in back.
As far as parts choose your poison...
Pads: Hawk, Posi, EBC, Wagner...
I put Wagner on mine and havn't had any issues and the wheels are much cleaner now without all the stock pad dust.
Rotors: AP Racing, Brembo, Powerslot...
I'm running stock rotors and have not had any issues.
You can upgrade to an after market system (calipers, rotors & pads) but the cost is going to be like upgrading to SRT8 brakes, mucho Hemi bucks.
Old Dec 19, 2008 | 03:01 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I was browsing a vendors web site today and found a front brake caliper upgrade kit for around 800.00. It's a 3 piston caliper upgrade with pads.
I'll PM a link to you.
* Just noticed your new to the forum, welcome and enjoy!
Old Dec 22, 2008 | 01:48 PM
uaedurango's Avatar
uaedurango
thanks, i would look forward to that. what is a PM? where should i look for it?
Old Dec 22, 2008 | 03:20 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
PM = Private Message.
At the top of the page look for Quick Links, it's a drop down menu, and towards the bottom of the menu under Miscellaneous select Private Messages.
Old Dec 22, 2008 | 05:11 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
There's a shortcut for PMs at the top of every forum page. Here's what it looks like, all you have to do is click on Private Messages that is highlighted in Red, see attached picture.
Old Jan 9, 2009 | 02:18 PM
betta510's Avatar
betta510
I wanted to get Wilwoods on mine but dam their pricey!
