Sponsored by:
Sponsored by: CARiD
Heater Panel Lights
Old Feb 22, 2009 | 11:13 AM
Mack_D's Avatar
Mack_D
Default Heater Panel Lights
Hi All,
The heater panel lights on my 2006 Charger went out. The unit works fine, but the lights are out. I researched this topic and found that to be a common problem. Most threads indicated that I need to change the module that controls the heater panel lights (cost is around $150). Does anyone have the part number or the part name (or is it simply the module that controls the heater panel lights)?
Old Feb 22, 2009 | 11:29 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I dont specifically have the part number but Ill move your thread to the Charger Section for better input. Hope this helps man... good luck If not, Ill post it to another section
Old Feb 22, 2009 | 11:44 AM
Mack_D's Avatar
Mack_D
Thank you for your help,
Old Feb 22, 2009 | 01:54 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Welcome to the forum, I also have a 06 Charger.
I've got heated seats and those switches have lights but I'm not familar with the heater panel light.
Can you help me understand what lights your talking about?
Old Feb 22, 2009 | 02:26 PM
Mack_D's Avatar
Mack_D
I am talking about the heater/ac switches (power level, heat/cool level, air output). The heater/ac itself works, but when you turn on the headlights, the interior lights do come on except for these three switches.
Old Feb 22, 2009 | 07:35 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I see, let me do some leg work and post back up.
Old Feb 23, 2009 | 11:47 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I couldn't find the part number for the HVAC control cluster. Can you stop by a dealerhip and get the part # from the service department?
Old Feb 23, 2009 | 07:32 PM
Mack_D's Avatar
Mack_D
I went to the dealer and ordered the heater control module. It should be in in a couple of days. Any hints or tips on how to remove the center bezel cover without the risk of breaking it?
Old Feb 24, 2009 | 07:39 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
The bezel pulls right off, I started up top turninng the vents all the way down then was able to get ahold and pulled and worked my way down to the bottom. I also had the ashtray assembly out but I don't think thats manditory.
Old Feb 24, 2009 | 11:10 AM
Mack_D's Avatar
Mack_D
Thanks for the input dude. I will definitely take my time doing this. Do you recall any clips in the center part of it or were they all around the frame of it?
