Sketch
plum, although you did a decent job on the most recent one, i like the older ones you did better because they were truer to THE CHARGER. this one all that is the same to THE CHARGER is the tires and rims. At least making the 4 door of THE CHARGER a 2 door, looked really realistic, because that could be done. this one is so far out there it isn't even an option.
loghead you are a retard
nick,
Did you bother to look at the overlay? Do you know what an overlay is?
Plum's overlay is a comparison between his model (the older one; the one you just said you like)and the '06.
So you think I'm a retard?
I also happen to be a structural designer; so I'm taking into consideration the things I know about taking a concept and making it real.
I've been turning wrenches, welding and fabricating since before you were a bad idea your parents had.
I've got some advice for you nick:
Learn how to spell and punctuate before you call anyone a retard.
The only being produced that is Charger for '06, is plastic badges. I'm glad they didn't use the script at least.
I've come to the realization -- well, as has been pointed out to me before -- the LX platform won't really support a Charger design all that easily. (Though I do like the 300 and Magnum, don't get me wrong)
It may not support everything we'd like to see, but if you restricted the areas you change to the nose (in particular, and not actually that difficult) and to putting two doors on the thing (alot harder, but not impossible), I think that a change for the better is possible.
For those of you in the peanut gallery who like the '06 as it is,go buy one; no one is stopping you. If you think it's badass as is, good for you; but there's no need to throw rocks at someone who's taking an honest look at the car and asking himself "what could be done with the existing cab and chassis of this car to make me like it?"
Go buy one.
Buy lots of them, and when in four or five years you've worn the thing out, I'll buy what's left of it and change it into what it could be.
Go buy one.
ORIGINAL: plum500
if that is your logic, then the old garbage is just a charger by plastic badges too
