Sponsored by:
Sponsored by: CARiD
VIN needed for 2006 SRT8 6.1 Hemi
Old Oct 22, 2009 | 10:00 PM
franklcpa's Avatar
franklcpa
Default VIN needed for 2006 SRT8 6.1 Hemi
I have purchased a 2006 6.1 Hemi with NAG 1 transmission off of Ebay. The seller is either unable or unwilling to provide me with the VIN of the 2006 SRT8 Charger that the engine was in when it was wrecked. I have been told that the VIN is not on the engine by a mechanic at the local dealership and told that it is by Chrysler customer service. I have located the following numbers, TNXE6166620143 which is on the block casting. I have also located the numbers that are on the attached transmission label.jpg file. These numbers are as follows, TI2TJ172660328 with a larger 662 below and to the right of the bar code and then P52108662AA on the lower part of the label. Also enscribed in the transmission is 617123:53. My question is exactly what are these numbers and is the VIN anywhere on the engine or transmission.
Thanks for any help that you can pass my way!!!
Attached Thumbnails VIN needed for 2006 SRT8 6.1 Hemi-transmission-label.jpg
Old Oct 23, 2009 | 07:22 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Welcome to the forum franklcpa.
There is a coalition between the VIN and the Engine Block; the last 8 characters of your VIN is etched at the back of the block, just behind cyl 7. That would be on the driver’s side @ the rear. I have no idea about the transmission.
Old Oct 23, 2009 | 08:10 AM
franklcpa's Avatar
franklcpa
Thanks for your help. I will check it out.
