Sponsored by:
Sponsored by: CARiD
3.5L Firing Order
Old Dec 28, 2009 | 11:32 AM
Adion's Avatar
Adion
Default 3.5L Firing Order
I started to notice when my car was sitting at idle it would start to knock bad like a misfire. I borrowed a code reader and i found out that cylinder one has a misfire, i came here to double check that cyl #1 is on the left side at the back right?
Old Dec 28, 2009 | 01:49 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
Welcome to the forum Adion.
If your looking at the front of the car Cylinder 1 is up front on the passanger side.
Old Dec 28, 2009 | 05:34 PM
Adion's Avatar
Adion
thanks, so far this forum has been very helpful, so i took the plugs out and there very soutty, like its running rich, i changed the plugs anyway now the car as soon as i turn it on it revs up to 2000rpm and die back down like amost stalls. it idles very hard, am i missing something? it never did this befor
Old Dec 28, 2009 | 07:01 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
What kind of plugs did you use.
Old Dec 28, 2009 | 08:21 PM
Adion's Avatar
Adion
i bought bosh platnium, i read somewhere that they should work just fine
Old Dec 29, 2009 | 01:55 AM
Adion's Avatar
Adion
could it be the PCV tubes?
Old Dec 29, 2009 | 08:55 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
It could be lots of things.
Try this, I found it on another forum and it makes sense...
First - swap the plug from cylinder one to cylinder 4, then swap the coil from cylinder one to cylinder 2.
erase the code, drive the car til the light comes back on, if you get:
301 you have a injector, egr, compression or vacuum leak in that cylinder.
302 its the coil
304 its the plug
