Sponsored by:
Sponsored by: CARiD
Need Help With Emissions!
Old May 17, 2010 | 03:52 PM
phasar's Avatar
phasar
Default Need Help With Emissions!
I have a 2006 Charger R/T, however, when I take the emissions test I keep being rejected because of:
1, Catalytic Converter EFF. NOT READY
2, Oxygen Sensor. NOT READY
Also DTC: Code P1521 INCORRECT OIL TYPE
The Dealer reset the P1521 code, But no one can tell me how long or far the vehicle has to be driven for the system to be ready.
I can't continue to fail emissions, any help will be greatly appreciated!
Old May 17, 2010 | 05:40 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the Charger section,
FF
Old May 17, 2010 | 10:18 PM
master tech's Avatar
master tech
Site Moderator & Tech
I'm guessing you have a 5.7L engine? If you do, there is a flash update for the oil pressure code. Also what is the weight oil that you are putting in the engine? Drive the car for 40 to 100 miles. Then you should be able to retest the emission.
Old May 18, 2010 | 10:56 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
FYI... You can do a quick check to see if your ready for inspection by:
Turnning the key to the On position without starting the car.
It's ready if the engine light does not blink.
If the engine light blinks when all the other indicator lights have gone out the emissions test are not in a ready state.
Old May 18, 2010 | 03:43 PM
baldyloxs's Avatar
baldyloxs
HMMM???? Im glad we dont have that here!!!!
Good Luck
Old May 19, 2010 | 07:31 PM
MangoInTX's Avatar
MangoInTX
Charger Moderator
That's just getting ready for a standard ODB II inspection test not real emissions "sniffing" tests like in strict states like CA.
Old May 20, 2010 | 07:49 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
I had a Ford Escort that wouldn't pass the emissions test down here in Florida one year (thank god we don't have them anymore). But anyway, the garage couldn't find the problem either after a couple of trips. So like I did in Pennsylvania, I went to my small hole in the wall garage that I had alot of work done, so the owner new me, and asked if there was someone out there that could "pass" me. Sure enough there was. $75 and I got my certificate. ALot cheaper than several repairs and trips to the test site.....
Good luck on your issue though.
