2009 Police Package Question
Iv bene looking for a bit and cant find info.. SOOO!
Here i am.
I have a double din dvd system in my cruzer in place of the stock stereo, Problem is when i turn the new stereo on my display cluster all dies and all my warning lights come on saying every problem with the car exists and i get no bus showing on the display.. When i turn the stereo off it all comes back on.. What wires did i not connect that is making this happen?
I used this same radio in another car and was fine (Not a charger)
Did the same set up i did for that and not working to well for this one.. Also the sound is crappy.. i dont think it is getting power from the stock amp either.
If someone could post a wire diagram of the stereo wires n such that would be super helpfull
Here i am.
There is a bypass wire kit that needs to be installed on the dodge vehicles, unlike other cars. You're new to the forum, and welcome, however one thing that is said time and time again here is that on Dodge vehicles, EVERYTHING is connected to the computer for data. So, when an aftermarket radio is installed, there is an additional harness that has to be installed somewhere to fool the computer that there is a radio there communicating with it. I think it is called the canbus bypass. This is where you problem most likely is.
Sorry, I don't have a wire diagram for you. Whenever I change out my radios, even though I have the knowledge to do it, I always have a garage do it in case there is ever a problem, they are liable and cover anything under warranty.
So in short, if you hooked up the radio, or had a friend do it, and the only harness you added was the actual wiring harness for the speakers in the back, you will need to get the bypass harness as well. This might also fix the amp problem as well. Since the computer isn't reading the radio data correctly, it might be preventing the amp from turning on for safety reasons.
I don't know the specs of the harness so I can't tell you anything about that. I can tell you though that when I had Best Buy do my install last time, the harness was $24. I don't even know where it plugged in to for it to work.
I checked with them last week and they said it was 300 bucks.. I was like YEAH! Im sure a WIRE HARNESS is that much..
Ebay has them plus a little electronic device for 80 bucks.
Or maybe these stereo guys were just the dumbest **** heads in the building?
Any idea of a part number or what i can ask best buy for?
Holy crap!!!! That isn't right. LOL!!! My entire install including the 2 harnesses and the dash kit was only around $80.
I have to goto work now, but I will look later when I get home. Unless someone pops in here before I do to take care of this.
Went back there today and now they are saying its 149 for the wire bypass kit... One day its 299 now 149.. HMMMM And thats JUSt for the kit not the mounting brackets or an install either.. Something sounds rotten in this picture
Trending Topics
Pin 2 and 13 are definite no-nos. They are the BUS wires. Don't use them.
You're probably shorting your BUS when you power up.
RADIO - (INSTRUMENT PANEL) 22 WAY
1 A300 18RD/OR FUSED B(+) (I.O.D.)
2 D54 20WT CAN B BUS (-)
3 X446 22BR/OR (NAVIGATION) UCI POWER FEED 2 PASS THROUGH
4 X431 22DG (NAVIGATION) UCI EXT RECEIVE
5 X430 22DB (NAVIGATION) UCI EXT TRANSMIT
6 X440 22YL (NAVIGATION) UCI DEVICE DETECT
7 X62 18GY/OR AMPLIFIED ANTENNA FEED
8 X303 18DG/TN (LOWLINE/MIDLINE I) AMPLIFIED LEFT REAR SPEAKER (+)
8 X51 18DG/DB (MIDLINE II/HIGHLINE) RADIO LEFT AUDIO (+)
9 X393 18DG/GY (LOWLINE/MIDLINE I) AMPLIFIED LEFT REAR SPEAKER (-)
9 X57 18DG/OR (MIDLINE II/HIGHLINE) RADIO LEFT AUDIO (-)
10 X304 18DG/BR (LOWLINE/MIDLINE I) AMPLIFIED RIGHT REAR SPEAKER (+)
10 X52 18GY/DB (MIDLINE II/HIGHLINE) RADIO RIGHT AUDIO (+)
11 X394 18YL/GY (LOWLINE/MIDLINE I) AMPLIFIED RIGHT REAR SPEAKER (-)
11 X58 18GY/OR (MIDLINE II/HIGHLINE) RADIO RIGHT AUDIO (-)
12 Z909 18BK/LG GROUND
13 D55 20WT/OR CAN B BUS (+)
14 Z433 22BK (NAVIGATION) GROUND
15 X437 22TN (NAVIGATION) UCI AUDIO REFERENCE
16 X436 22WT (NAVIGATION) UCI AUDIO LEFT INPUT
17 X435 22RD (NAVIGATION) UCI AUDIO RIGHT INPUT
18 - -
19 X202 18DG/VT (LOWLINE/MIDLINE I) AMPLIFIED RIGHT FRONT DOOR SPEAKER (+)
20 X292 18DG/YL (LOWLINE/MIDLINE I) AMPLIFIED RIGHT FRONT DOOR SPEAKER (-)
21 X201 18GY/VT (LOWLINE/MIDLINE I) AMPLIFIED LEFT FRONT DOOR SPEAKER (+)
22 X291 18GY/YL (LOWLINE/MIDLINE I) AMPLIFIED LEFT FRONT DOOR SPEAKER (-)
RADIO - (INSTRUMENT PANEL) 10 WAY
1 X703 22DG/OR (LHD HANDS FREE) LEFT AUDIO OUTPUT
1 X722 22LB/DG (LHD NAVIGATION) MICROPHONE 2 IN (+)
1 X703 20DG/OR (RHD HANDS FREE/POLICE) LEFT AUDIO OUTPUT
1 X722 20LB/DG (RHD NAVIGATION) MICROPHONE 2 IN (+)
2 X704 22DG/YL (LHD HANDS FREE) RIGHT AUDIO OUTPUT
2 X712 22DG/LB (LHD NAVIGATION) MICROPHONE 1 IN (+)
2 X704 20DG/YL (RHD HANDS FREE/POLICE) RIGHT AUDIO OUTPUT
2 X712 20DG/LB (RHD NAVIGATION) MICROPHONE 1 IN (+)
3 X439 22BR (NAVIGATION) UCI ID
4 X793 22DG/YL (LHD NAVIGATION) MICROPHONE FEED
4 X793 20DG/YL (RHD NAVIGATION) MICROPHONE FEED
5 - -
6 X795 22DG (LHD HANDS FREE) COMMON AUDIO OUTPUT
6 X795 20DG (RHD HANDS FREE/POLICE) COMMON AUDIO OUTPUT
7 X792 22GY (LHD NAVIGATION) MICROPHONE IN (-)
7 X792 20GY (RHD NAVIGATION) MICROPHONE IN (-)
8 X835 22OR/GY (LHD NAVIGATION) SENSOR GROUND
8 X835 20OR/GY (RHD NAVIGATION) SENSOR GROUND
9 X444 22GY (NAVIGATION) UCI USB DATA (+)
10 X445 22DB (NAVIGATION) UCI USB DATA (-)
18 - -
5 - -
