Where can I buy the noesp module??
I want to buy one of these noesp modules for my 06 charger, when I search for noesp.com I bring up a bunch of blogs about it but no site to actually purchase one. Where can I buy one? And wats this "key trick" tht Ive heard about?
Whoops, sorry didn't know the website was shut down (noesp.com), have not looked into this mod for awhile.
The key trick won't work on your '06 model, only mid-year build '07 models and up, first generation.
I plan on buying the diablo tuner, will the disable ESP option totally disable it or will I still the the noesp mod?
I installed a switch inside the center console on my wifes R/T to kill the power to t he ESP system. Pull the center console and locate the violet wire with the light blue stripe. That is the power to the ESP accelerometer. Cut that wire and inatall a switch in it. I soldered extra wire so that I could mount the switch inside the center console. I used a small toggle switch and mounted it inside the bottom of the largest coin slot. That way it can't be accidentally hit.
When the switch is in the off position ESP/BAS is completely disabled until you turn the switch back on and restart the car.
If you've never driven these cars with no traction control you will be surprised. They are a totally different beast.
Trending Topics
