oil filter
You have to remove the black splash guard to get to it. Once you have it off, if you are laying on your back under the car where you are sorta in the middle area with your head near the oil pan, the filter will be kinda on your right.
Hope this helps. I looked to see if I had a pick, but I didn't
I have an 06 R/T as well, mine didn't have a splash guard covering the filter location but it is kinda to ur right whenever u r laying under the car from the front. Also I always use FRAM filters n the orange box "PH16".. And the bolt to ur oil pan should b a 13mm socket..mine is
