2006 Charger SXT heater/A/C problems - clicking and stuck
My charger was making a clicking sound when I would first turn on the heater or A/C and once the heat or cool air started pumping it would stop. WELLLLL, now the clicking is continuous whether I have the fan turned on or not, and the air will only blow straight, it will not move to defrost or to the feet or anywhere else.
Anyone have any suggestions or do I just need to take it to the shop and will they rob me to fix it (yeah I know, we all know that answer)
THANK YOU!!!!
THANK YOU!!!!
well, sounds like you either need a Mode Door motor/linkage or the Mode door itself broke off.
A mode door motor should take no more than an hour to change,But the door itself takes about 7 hours.
The motor is above the gas pedal, if you know what you are looking for. Try a New motor, and inspect the linkage, sometimes the teeths goes out of placement.
It kinda looks like this
The Door itself is inside the dash. And if you are going to replace the mode door, Might want to conside replacing the A/C evaporator with it too, since you alrdy spending few hours to take it out anyway.
well, there is still hope. The Passenger side is the Recirulation door motor. And if you have a Dual Zone control, there is a blend door motor there. I hardly see doors break off on Chargers, maybe you just need the motor. I would remove the motor, and stick my finger into the door slot, and see if it spins 360 degrees instead of supposely 45 degree.
Both picture below is on the driver's side, above gas pedal. you remove the Knee Bolster to get to it.
#7 is the blend door, #4 is the mode door motor.
If you remove the motor, whats behind #4 looks like this
I've seen the linkage behind the motor pop off few times, inspect it. But I hope you or your mechanic remembers where each piece goes.
ETA - I pulled it apart again today and it turns out this pic was good enough to help me put it back together correctly.
