Sponsored by:
Sponsored by: CARiD
Engine cover on bottom
Old Aug 31, 2005 | 01:51 PM
BigBear's Avatar
BigBear
Default Engine cover on bottom
Is that thing really necessary? I'd like to do my own oil changes and saw it under there. Is there much to removing it once I get the car on jacks? Thanks.
Old Oct 1, 2005 | 12:27 AM
draftingmonkey's Avatar
draftingmonkey
Default RE: Engine cover on bottom
Don't have the Charger but have a Magnum. More than likely the same. If it is remove the screws that hold the front belly pan to the front bumper on the bottom and the screws/bolts at the rear of the front belly pan. Then remove the screws/bolts from the rear belly pan and you should be there. Hope this helps.
Old Oct 4, 2005 | 11:44 PM
COCharger's Avatar
COCharger
Sounds like it is an easy remove for changing oil. However I wouldn't want to remove it permanently. It sounds like it acts as a "skid plate" and I would much rather have it take the abuse instead of sending rocks and who knows what up into the oil pan and other components down there.
