Sponsored by:
Sponsored by: CARiD
2006 Charger Tie rod end problems
Old Nov 17, 2012 | 04:16 AM
Deadeye11's Avatar
Deadeye11
Default 2006 Charger Tie rod end problems
I have a '06 Charger R/t. The question is, are there problems with the tie
rod ends? I only have 65,000 miles on it & they are telling me the P.S. inner tie rod end is shot. So soon?
I replaces both inner tie rods. Used Moog. Took care of that problem. Also had a noise in the front end when going over bumps. Couldn't find any loose parts. Replaced the Sway bar bushings. Also used Moog. That also took care of that problem. Be sure you measure the diameter of the sway bar. There are 3 different sizes for the Charger.
Old Nov 18, 2012 | 03:27 PM
Tas95xo's Avatar
Tas95xo
I have an 07 R/T and have only 41,000 mile and both outer tie rod ends replaced. Due to the fact they have no grease fittings on them they wear fast unlike most vehicles. It's the only thing about car I hate. You could see if someone make on with a fitting in them.
Old Nov 18, 2012 | 10:35 PM
POWER SEDAN's Avatar
POWER SEDAN
I know Advance Auto Stores sells outer tie rods with lifetime warranty, which do have zerk fittings.
