Sponsored by:
Sponsored by: CARiD
A/C makes weird noise and doesnt put out cold air
Old Aug 18, 2013 | 10:24 AM
Andy07Charger's Avatar
Andy07Charger
Default A/C makes weird noise and doesnt put out cold air
Hey ppl I've had my 2007 Charger over 2 years now. A/C just gave out 5 months ago. When I turn it on after a few seconds I hear a raddleing and even after I shut it off it will take 6 to 8 sec to stop making that noise, plus it puts out no cold air at all. I put in some freon not to long ago but it only lasted about 1 month.
I'm a welder so for me the heat doesn't bother me but I do have a lil girl and so I def have to get it fixed.
Old Aug 20, 2013 | 05:49 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
The rattling noise could come from anything. Clutch, compressor, fan. I would take it to a garage and get an estimate. If you put refrigerant in and it leaked out in a months time, I would guess that the compressor is bad though.
Old Aug 20, 2013 | 10:39 PM
steak59's Avatar
steak59
If compressor is leaking, it could be covered up in oil.
Evaporator core is very common leak point of Charger built from 05-07. If no oil is found alone all of the A/C component, it is safe to say you need a Evap core. While you replace the Evap Core, probably want to buy a Recirculation door as well. they usually breaks off when you take it apart.
Regarding the noise... Put some oil and freons in and see if noise stops?
