Sponsored by:
Sponsored by: CARiD
2013 SXT Plus Outside Temp stuck at 75 Degrees
Old Oct 7, 2013 | 10:57 AM
Chrislorl's Avatar
Chrislorl
Originally Posted by ledman
Interesting. I will have to pay more attention to mine to see how long it takes to get accurate temp readings, so far I have not noticed anything out of the Norm.
Did the dealer replace the temp sensor?
No, no work done. I figure since it was the second line on the RO the tech had the car running when checking the exhaust noise. By the time he got to the temp it had corrected.
Old Apr 25, 2014 | 11:43 AM
Chrislorl's Avatar
Chrislorl
Just an update on this issue. After being told there was no problem, operating as designed, blah, blah, blah. I go in today for an oil change (still free) and I am told there are 2 flashes available. Of course they can not tell me for what, just for the BCM. SO I figure I will get it done and then look up the code on the RO. So I find "Program BCM PER TSB 08-047-13". I do a search and find that it is to correct "Incorrect Exterior Temp display".
So after two RO's on the subject, and emails to Dodge, no one ever follows up or notifies me that they now have a fix for something that wasn't broken.
Customer service to the max, Sure I will give a 10 on the CSI review.
One other flash done to for No Audio on the radio. Amp communication failure 08-032-12.
