Sponsored by:
Sponsored by: CARiD
ESP/BAS light not turning on at startup 2006 charger rt
Old Dec 4, 2013 | 02:23 PM
juancaballero1's Avatar
juancaballero1
Default ESP/BAS light not turning on at startup 2006 charger rt
My esp/bas lights are not turning on during startup nor is the airbag light. I get a single chime upon driving but no error message or check engine light come on. Has anyone had this problem? 2006 charger rt
Old Dec 4, 2013 | 05:15 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Did you buy it used? Have they worked since you bought it?
Old Dec 4, 2013 | 05:45 PM
juancaballero1
yes I bought it used about six months ago but I didn't notice any of the lights until I tried to do the key trick
Old Dec 4, 2013 | 06:05 PM
TNtech's Avatar
TNtech
I do a TON of electrical and module repairs on Chargers, Magnums and 300s from used car lots all the time. It seems that body style is overwhelmingly popular among wreck rebuilders for some reason.
80% of the problems I see from them are the configuration issues from using modules/computers from salvage cars that have different build configurations. They will set tons of troube codes, that won't go away, sometimes ending up with multiple modules having to be replaced new.
I would start by hitting a dealer and ask them for a "Scan Report" on your car from WiTech and have them print it out for you. They can even put it on a jump drive as a PDF file. If there are any mixed VIN numbers and such, i'll be able to pick out whats up.
Old Dec 4, 2013 | 07:31 PM
juancaballero1
I bought his car from the first owner, he bought it brand new and confirmed it on title and on carfax... Car does not have any mechanical or electrical issues or check engine light on but just curious why thise lights did not warm up!
Old Dec 4, 2013 | 08:04 PM
TNtech's Avatar
TNtech
OK then. If there is more than just one warning lamp not doing a bulb check, it's likely a cluster issue. I do remember one like this from before though. There was a fuse in the trunk fuse box that got knocked out. Think it was a 5 amp one, but can't remember exactly. The circuit was an obscure one.
Old Dec 4, 2013 | 08:09 PM
juancaballero1
I will go through the fuse box and ill get back to you with any results! Thanks!
Old Dec 5, 2013 | 07:27 PM
juancaballero1
It did the diagnostic on the EVIC and it shows last chime to be the airbag and give code VMM 418? Do you know what that code is?
Old Dec 6, 2013 | 07:07 PM
TNtech's Avatar
TNtech
I don't know what that is. Any codes should be one letter and 4 numbers.
Example: P0100
U1122
C2233
B1405
Old Dec 7, 2013 | 08:32 PM
POWER SEDAN's Avatar
POWER SEDAN
418 VMM is just Vehicle Memory Module, this should be displayed in EVIC everytime during startup, since it represents what version module you have.
