Sponsored by:
Sponsored by: CARiD
06 charger rt vibration
Old May 5, 2016 | 10:21 AM
Goldenboy8822's Avatar
Goldenboy8822
Default 06 charger rt vibration
I have a 2006 Dodge Charger rt and it idles pretty rough when at a stoplight and also when I'm slowing down there's a vibration..and sometimes when I turn onto a street I slow down hit the gas and the car kinda hesitates can anybody help me with this problem?
Old May 5, 2016 | 01:01 PM
n8ech's Avatar
n8ech
Golden:
Please provide more information such as how many miles are on the R/T, and any recent service history.
How long have you owned it? Are you getting a CE light, or other warning light on the speedo cluster? From the sound of it, you may have multiple issues going on here.
Don
Old May 5, 2016 | 03:40 PM
Goldenboy8822
Originally Posted by n8ech
Golden:
Don
4 years no lights on dash or nothing just runs rough at light and when slowing down mechanic said could be front motor mounts
Old May 5, 2016 | 06:07 PM
n8ech's Avatar
n8ech
That is a start. How many miles on it? Has it ever been tuned up?
You should be able to check the engine mounts fairly easily by opening the hood, and with the trans in drive and then reverse apply a bit of throttle while keeping your foot firmly on the brake.
If the engine moves up or side to side more than 1-1.5 inches, you may have a bad mount.
If not, they are probably ok.
The rough idle could be a vacuum leak from the intake or a hose. The vibration when slowing could be a drive shaft U joint on its way out.
Don
