Sponsored by:
Sponsored by: CARiD
2010 Dodge Charger cigarette lighter
Old Feb 27, 2017 | 03:54 PM
Ddgharleymom4@yahoo.com's Avatar
Default 2010 Dodge Charger cigarette lighter
I recently bought a 2010 Dodge Charger. It does not have the original console because it was a police car. The wires to my cigarette lighter have been cut off. I need to know the wiring diagram for it.
Old Feb 27, 2017 | 04:06 PM
Moving this to the correct section for ya.
Old Feb 28, 2017 | 09:14 AM
You can pick up a Haynes or chiltons manual for cheap that will contain wiring diagrams.
Old Feb 28, 2017 | 07:46 PM
brian102's Avatar
brian102
not sure if it helps, but a lighter port is just a hot wire and a ground... nothin fancy. certainly not worth digging through schematics of the cars electrical system. they probly used it to hardwire some accessories, the cut wires should be in line of sight behind the outlet. or at least thats where i would look, if not it would be easier to just run a new hot wire to it and a short ground to a screw in the body. if you do run a new wire put a fuse on it... i've blown dozens of lighter port fuses in my life lol.
Old Jul 22, 2022 | 03:47 PM
Steve210sa's Avatar
Steve210sa
I'm having the same issues the entire wiring harness in my dash looks like they just decided to cut everything out. I'm missing both 12v accessory connectors, connector for the seat warmer and two or three other connectors...... Not sure what they go to.
