Sponsored by:
Sponsored by: CARiD
Antifreeze
Old Apr 4, 2017 | 05:39 PM
Russ528's Avatar
Russ528
Default Antifreeze
Hi all
I have a 2012 Dodge Charger
And after I've driven for a bit I shut the car off and as I come out of my car I can smell anti freeze but I dont see any leaks or anything nothing on the ground or anything
Don't know what it could be
Any thoughts on this would be appreciated
Russ
Old Apr 4, 2017 | 05:43 PM
Moved to the correct section. Most likely a pin hole leak in the hose or radiator. Gotta check everything out.
Old Apr 4, 2017 | 10:49 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
What engine do you have? Borrow a pressure tester from a parts store.
Old Apr 5, 2017 | 06:19 AM
Russ528's Avatar
Russ528
antifreeze
3.8 its an SE
Old Apr 5, 2017 | 06:25 AM
Russ528's Avatar
Russ528
Antifreeze
That's just it
Monday morning I got home from work walked into my apartment and then I went back down stairs to check. The system was still under pressure I looked every where from the hoses to the thermostat housing etc. etc. etc. And didn't see anything. Nothing was dripping or smoking. None of that
Oh well ill take it to my mechanic Thursday morning to have it checked out
