Sponsored by:
Sponsored by: CARiD
2016 Dodge Charger ATC Module Location
Old Apr 7, 2017 | 10:00 AM
ajslawntruck's Avatar
ajslawntruck
Default 2016 Dodge Charger ATC Module Location
I was wondering if anyone knows where the Module is located for the ATC Climate Control Module under the dash. I need to replace it with this part number 68334969AA and don't want to tear up the whole dash trying to locate it. Thanks
Old Apr 8, 2017 | 06:20 AM
Kevin Nguyen's Avatar
Kevin Nguyen
yes, me too. I need to replace it with this part number 68334969AA
Old Oct 21, 2018 | 10:50 PM
ajslawntruck
Anyone?
Old Oct 22, 2018 | 12:35 AM
primem's Avatar
primem
if the hvac control module is what you need to replace....its behind the glove box
Old Oct 22, 2018 | 12:54 PM
ajslawntruck
Thank you, do you know if I need to remove the glovebox or is it accessible under?
Old Oct 22, 2018 | 11:37 PM
primem's Avatar
primem
remove glove box
Old Oct 23, 2018 | 08:07 AM
ajslawntruck
Awesome! Thank you!
Old Oct 5, 2019 | 07:49 PM
Links charger's Avatar
Links charger
Default HVAC module
2012 Charger R/T. I am getting a loud repetitive tapping sound inside the dashboard that lasts for about 30 seconds whenever I switch airflow modes. I'm assuming that something came loose inside the HVAC module. Is this something I can swap out?
Old Oct 5, 2019 | 09:14 PM
primem's Avatar
primem
the sound is the hvac control module trying to calibrate the blend doors..but something is broken
could be a hvac case broken linkage, blend/mode door.
you need to locate which actuator is making the noise (there are 3 or 4 depending on the build) remove and inspect.
Old Oct 6, 2019 | 10:40 AM
Links charger
Can I get to them if I pull out the glove box?
