Engine that goes out on my 2007 Dodge Charger
Hello everyone, I am the proud French owner of a 2007 Dodge Charger. I am writing to you because I can not find an answer to my question in France.
So for you just explain, I bought a Dodge Charger 2.7 V6 with a broken engine. I own another Dodge Charger 3.5 V6 with a body out of service (Rust on 80% of the bodywork.
So I install the 3.5 engine instead of 2.7. The engine worked perfectly before disassembly.
So I install the engine, I replace all the electrical harness of the engine and the dashboard to be sure it is the same. I go back all the components (calculators, BSI, and all the parts adjacent to the engine).
I turn the key, the engine starts and runs normally until it rises to "normal" temperature. And at a certain point, the engine speed increases suddenly, then goes down again and a red light-like light comes on and flashes. The engine runs differently, oddly even. And either he holds or he cuts himself off.
If I try to restart, it starts normally and runs correctly and re-belotte after a few minutes ...
So, I checked and even replaced the probe that is in the pipe after the air filter and the throttle body.
Would you know what problems I could look into? Thanking you
