Sponsored by:
Sponsored by: CARiD
Need help car won’t start
Old Sep 8, 2018 | 04:47 PM
Harley King's Avatar
Harley King
Default Need help car won’t start
I have a 08 Dodge Charger 3.5. I was going down road and a engine light came on and sec later car power to engine shut off but I still had power to roll windows down and everything but it would turn on but does crank. I heard the fuel pump on right not turning on so I changed both and tried to start and the crank time lasted longer but didn’t start and then my engine came back on since it died. I check for spark with a screwdriver and it did spark. I put starter fluid in air filter and it lights it but doesn’t turn on and almost like spits it back out. I have code for battery level lower than normal, air throttle which is probably from me opening it, fuel pump/level, and oil sending sensor. Please help? Car has 150k miles
Old Sep 17, 2018 | 02:11 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
In the underhood fuse box, Swap relays 9 and 22 with 16 and 17
Old Sep 17, 2018 | 02:15 AM
Harley King
I found out it has code 16? Which how do I figure if it’s sensor, jumped a tooth, or timing chain broke
Old Sep 17, 2018 | 07:30 AM
Code "16" is not valid. How did you come up with that?
Old Sep 17, 2018 | 10:38 AM
Harley King
P0016 which is the correspondence btw crank and cam sensors
Old Sep 17, 2018 | 11:40 AM
TNtech's Avatar
TNtech
Yep, sounds like timing belt broke or jumped.
