Sponsored by:
Sponsored by: CARiD
07 2.7L charger making intermittent grinding noise
Old Feb 21, 2019 | 04:02 PM
fortyways's Avatar
fortyways
Default 07 2.7L charger making intermittent grinding noise
This car is truly frustrating. About two weeks ago on the way home from the dmv i noticed a grinding sound coming from the engine bay, which went away ten seconds later. it’s been happening since then.
it happens all the time, in park, neutral, reverse, drive, etc. whether i’m moving or not, so i ruled out the brakes and transmission. it’s a noise coming from the engine bay that will happen randomly, for about 10 seconds and also will slow the engine down a little bit. sometimes it’s a very light grinding and sometimes it sounds like something is getting ripped apart, and i can feel the grinding noise in the brake and gas pedal (not when pressing either).
i dont know what it is and am afraid to take it to a mechanic because i’m in a position where they can tell me whatever and i’d have no way of knowing if they’re lying.
if anyone can help, the main point is that it comes on intermittently, for 5-15 seconds at a time, then goes away. it’s like there’s something that’s actually engaging on either the timing belt or serpentine belt. someone help, this noise is driving me crazy
Old Feb 21, 2019 | 07:31 PM
Bearing going out in something. Need to figure out what it is. Pull the belt, and spin everything by hand. (well, not the crank, but, you get the idea.) See if anything feels 'odd'.
