Sponsored by:
Sponsored by: CARiD
2010 Dodge Charger SXT C2100
Old Jul 21, 2019 | 12:40 PM
CheesyNinja's Avatar
CheesyNinja
Default 2010 Dodge Charger SXT C2100
I have a 2010 Dodge charger SXT with the ABS, Esp, and traction light on. I pulled the codes and got C2100. Which is where the ABS module has less than 7.5 volts. I checked the voltages of the ABS fuses under the hood and got 12v for fuse 13 however 6.5v for fuse 11. I am confused on where to go from here
Old Jul 21, 2019 | 03:26 PM
Did you check both sides of the fuse? Might be thinking about being blown. If you have low voltage on both sides, (I would be tempted to just replace it in any event.... just because.....) then need to find out where the power feed comes from, and what the issue is. (probably just a bad connection.....) Wiring diagrams would be REALLY helpful for you to have.
Old Jul 21, 2019 | 08:55 PM
CheesyNinja
I took out the fuse and measured the voltage from the prongs in the fuse box. Where would i find the wiring diagrams?
Old Jul 22, 2019 | 08:33 AM
Service manual, (real FACTORY service manual, Chilton or Haynes won't cut it.) Could try here as well.
Old Jul 22, 2019 | 01:22 PM
CheesyNinja
Used the link you sent and found what I needed. I tested the voltage from the connector and it was 12v with the car off. I cleaned off the connections on the module itself and that seemed to clear the code. Thank you very much!
Old Jul 22, 2019 | 06:24 PM
It would be really cool if it were actually that easy.
