Sponsored by:
Sponsored by: CARiD
2015 Dodge Charger SE Check engine light mystery
Old Nov 4, 2019 | 10:09 PM
Joe99's Avatar
Joe99
Default 2015 Dodge Charger SE Check engine light mystery
Hello all! So i have a 2015 Dodge charger SE and it has about 95k Miles...Recently the check engine light went on after i put a fuel additive in the gas tank, little did i know you needed a special funnel and some of the additive dripped down in the vent that catches the excess fuel and didn't make it into the actual tank, any ways to get that check engine light off? I'm assuming the evap canister is clogged or something and needs to be cleaned out or replaced. I also have noticed (separate issue) when i fill up to a full tank there is a very strong raw fuel smell in the cabin. Any ideas on how to fix these issues? Thank you guys!
Old Nov 5, 2019 | 07:51 AM
Check codes, see what it's whining about. That will tell you where to start.
