Sponsored by:
Sponsored by: CARiD
Hemi Tick
Old Nov 16, 2019 | 01:25 PM
ZEN357's Avatar
ZEN357
Default Hemi Tick
Can anyone shed some light on Hemi tick? As in, what is it / is it a problem / how do i fix it?
Its so annoying!
Old Nov 16, 2019 | 03:53 PM
Several things can cause it.
According to theory, the injectors are loud, and can be the sound you hear.
Exhaust manifold bolts break, and can give you a tick. (exhaust leak)
Lifters can fail, and that will definitely give you a tick. This can also lead to galled/destroyed camshafts.....
If you have the MDS system, sticking solenoids, or them simply not sealing completely, will cause a tick.
Using the wrong weight oil can cause a tick.
The VVT system can make some interesting noises as well........
First step is, figure out which one is causing it. And that is not always an easy task, as most of them are inside the engine.....
Old Nov 29, 2019 | 11:15 AM
ZEN357's Avatar
ZEN357
Thank you for your help!
