Sponsored by:
Sponsored by: CARiD
2010 Dodge Charger RKE Location
Old Mar 1, 2020 | 09:47 PM
wesley.h's Avatar
wesley.h
Default 2010 Dodge Charger RKE Location
Hi guys,
I've a 2010 Dodge Charger, slowly fixing the things that need to be replaced on it. Does anyone have an inkling of the location of the RKE module? I can't find much of that info with google.
Wes
Old Mar 2, 2020 | 12:23 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
It's called a "wireless ignition node", it's the module that has the key switch, aka SKREEM. Does double duty as both wireless receiver and sentry key module.
Old Mar 2, 2020 | 08:35 AM
wesley.h's Avatar
wesley.h
I've just seen it called a RKE. But, alright. I bought a replacement anyhow, just wondering where the part is in the car, to replace it.
Old Mar 2, 2020 | 09:04 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Apparently you missed the part where I said "it's the module that has the key switch". You can't program it anyway, also if you can't even figure out where it goes after someone tells you what it is...you might wanna take it somewhere...even if you do figure out where it goes, the minute you try to start it it's gonna lock your PCM since the module will not have initialized and programmed to the PCM.
Old Mar 2, 2020 | 09:22 AM
wesley.h's Avatar
wesley.h
I have no interest in self install, just looking for details on installation so as to not get ripped off by an installation/ tech shop.
Old Mar 11, 2020 | 02:00 AM
master tech's Avatar
master tech
Site Moderator & Tech
First of all why are you replace the WIN module in the first place. If you are having an issue. Did you check with the dealer for a K08 recall. the replace the WIN and two fobs. Besides you will need the dealer add the secret key code.
