Sponsored by:
Sponsored by: CARiD
2006 Charger not Starting (electrical)
Old Apr 28, 2020 | 03:41 AM
Cody Dubray's Avatar
Cody Dubray
Default 2006 Charger not Starting (electrical)
2006 Dodge Charger won’t start. Just recently rebuilt engine and ran very well. Then took spark plugs out to put new ones in that just came in the mail but left some light on overnight and killed battery. Charged battery back up but now it doesn’t even make a noise besides a relay clicking once when trying to start. Red light is on on dash as well *** check engine light and basically every other light on the dash as well as a dinging sound when turning the key to start. Only code is u0100. I took another Ecu and plugged it in. It started for about 2 sec then immediately died. Did this 2 more times them same thing as before, wouldn't do anything when key was turned. Any advice on what is going on?
Old Apr 28, 2020 | 06:58 AM
Security issue. There should be a procedure to recover from it, but, I don't know what it is.
Old Apr 28, 2020 | 01:12 PM
Cody Dubray
any more info on this anybody?
Old Apr 28, 2020 | 04:43 PM
Could try unlocking the drivers or passenger door twice with the key, see if that helps at all. Dodge used a lot of different recovery methods over the years....
Old Apr 28, 2020 | 09:04 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
So you took another random PCM and just plugged it in lol? U0100 is 'lost communication with PCM'. All you did trying another one without matching SKREEM to it was lock the PCM. That's why it kept shutting off and is now locked. I doubt you left a light on overnight that killed because these things have a timer, the CAN bus shuts off power to that accessory after a set amount of time so as to NOT run down the battery since these cars are so voltage sensitive (if the battery is shot or has bad cells it won't matter). You need to figure out what killed your battery the first time and then you need to get a properly programmed and matched PCM to your vehicle.
