Sponsored by:
Sponsored by: CARiD
Power seats issues
Old Jun 13, 2020 | 10:04 PM
Talic's Avatar
Talic
Default Power seats issues
Hello everyone....
im having an issue with my 2013 Dodge Charger RT power seats.
One day everything was working perfectly fine then the next when I went to move the seats I realized it didn’t work....not going forward, backwards, up nor down, the lumber portion not even working and this is on both driver and passenger side
I checked every fuse in the trunk and that’s perfect.
I checked all the connections under both seats...nothing
Not even making a click or sound at all
One thing I did find weird is besides both power seats not working, the adjustable pedals along with the power tilt/telescoping stopped working also
the heat/cooling features are working though. Any tips or advice would be greatly appreciated
Old Jun 14, 2020 | 08:31 AM
Gotta be a blown fuse some where.
Old Jun 14, 2020 | 01:02 PM
Talic's Avatar
Talic
thanks for the response.
where else would a fuse be? I pulled every single fuse out of the trunk box and tested each fuse...all worked
Old Jun 14, 2020 | 01:25 PM
Real possibility its a circuit breaker, and not a fuse..... I don't have any documentation for it though.....
Old Jun 14, 2020 | 05:28 PM
Talic's Avatar
Talic
Any idea where a circuit breaker would be located? I might set up an appointment with dodge sadly...just wanted to try and fix it myself
Old Jun 14, 2020 | 07:24 PM
If you have your owners manual, it should tell you in there. Or maybe on the cover of the various fuse boxes? (Is there more than one??) I think you can download the owners manuals for free from dodge, if you don't have one.
