Sponsored by:
Sponsored by: CARiD
2016 Dodge Charger sxt won’t start please Help
Old Oct 8, 2020 | 03:37 PM
RudeGod's Avatar
RudeGod
Default 2016 Dodge Charger sxt won’t start please Help
It’s not the Starter, Alternators or Battery...Just had engine Replaced and Starter and my Battery Tested Good....Car will start one day then won’t start for 2-3 Days...as soon as it starts it runs good but when I cut the car off it won’t start again....no check engine light when car starts but when it’s in Run and not started check engine light is on....I’m confused I haven’t had this problem ever since I’ve had the car....anybody had this problem before please let me kno the solution
trying to add the video but it’s not letting me
Old Oct 8, 2020 | 05:08 PM
Will the engine crank, and not fire, or do you get nothing at all?
Old Oct 8, 2020 | 06:04 PM
RudeGod's Avatar
RudeGod
It won’t start it might click real soft one time and that’s it...if u sent me ya email I can send u a video
Old Sep 8, 2021 | 07:32 AM
Blovely's Avatar
Blovely
Default Crank no start! Tried everything!? LOOK AT THIS
Charger 2010 didn't start only cranked cranked no start.
i had replaced the alternator. Relays. Battery and fuel pump. And same o thing kept leaving me with no start. Just click click crank nothing!!!
Finally I seen where u hit the pump and it started. But then stopped again. So I removed the ring lock. And took out the two part with the springs removed the harness.
Well that part where the harness connects has 4 or five pins. One of the pins had like plastic that had melted around it I'm not sure why it had melted plastic but it did. So I took a box cutting blade and carefully. And be careful not to break the pin. I cut the plastic off the pin. That plastic was keeping it from making a connection. I'm not sure if this is a recall.but let me tell u I'm a female from Texas it's summer time. I'm 5'1 and that little pin with melted plastic caused me to be a grown mechanic that pin was the culprit . Once removed and put harness back on.. wow ! U could literally hear the fuel pump come back to life. If you are having this issue check the piece out and see if the pins are clear. It saved me so much money.
Good luck charger owners.
