hello, so i have been fixing up my charger that has been broken for a while cylinder 1 and 3 were broken so I have new pistons in both of them. now that i got that out of the way i have a misfire in cylinder 1 roughly 24 at start up and it only misfires at 2700RPM or greater. you can tell it sputters at that point.
I have tested the coils from cylinder 1 to cylinder 3 no difference.
looked at spark plugs and no improper fowling or any abnormal about the spark plugs.
Will be doing the compression test Monday.
what should I do based off if it fails or if its good.?
I have attached my hp tuners logs
anything helps thanks.
Quote:
Hp tuners vcm will work on it. As I said it was a HPtuners log.Originally Posted by HeyYou
Can't read the log file. Need to save it in some format that notepad, or something will understand.
close
- Join DateApr 2010
- LocationClayton MI
Liked:4,223 Times in 3,915 Posts
Quote:
Is there a free download for that?Originally Posted by TheFavSRT
Quote:
https://www.hptuners.com/downloads/ the first link all hp tuners people use this to look at the logs. Yes it is free. Originally Posted by HeyYou
close
- Join DateApr 2010
Quote:
Ok, I LIKE that. Very cool.Originally Posted by TheFavSRT
Watching the initial run time, it almost looks like there is a vacuum leak there somewhere. Given that cylinder 1 is the only one misfiring, gotta be someplace that only affects that cylinder. Intake leak? Might try spraying around with some carb cleaner at idle, and see what happens.
