Sponsored by:
Sponsored by: CARiD
A/C passenger side not working properly
Old Sep 13, 2021 | 10:12 PM
jmendez's Avatar
jmendez
Default A/C passenger side not working properly
I have a 2016 dodge charger R/T
So i am having a problem with my passenger side AC (the car has a dual zone system) , the driver side if i change the temperature it works just fine, but as soon as i activate the heater on the passenger side nothing happens, it stays blowing cold although the temperature is set to the highest heat possible, if i activate defroster/floor vents it will swap out to that mode but the temperature will not change whilst the driver side will respond accordingly to the set temperature, If i raise or lower the fan speed both sides will react accordingly and either blow harder or lower but the temperature on the passenger side will not change whatsoever
Old Sep 15, 2021 | 04:09 PM
DodgeCares's Avatar
DodgeCares
Hi jmendez,
We understand you are reaching out to fellow forum members, however if you are not able to remedy this concern with the advice provided here; we kindly recommend connecting with your local Dodge dealer. If you are in need of any assistance with that process, our team is available via private message.
Rob
Dodge Cares
