Sponsored by:
Sponsored by: CARiD
2007 2.7 charger
Old Nov 16, 2021 | 07:26 AM
Reapercrew's Avatar
Reapercrew
Unhappy 2007 2.7 charger
Hello everyone,
new here and i am a DIY kinda of guy. my son had this chargewr sitting for 2 years then decided to give it to me. well i found that his motor was blown so i searched around and found one on ebay (reman) for 2k. *first mistake* so i drove to LA pick it up and proceeded with the instal. everything went smooth dropped new motor in with new sensors and tin ware ext.... after 2k miles driving on normal day i came to a right hand turn and as i did the car shut down completly. woulkd not start again. so took my heads off and the shop told me the intake valves were all bent. so after getting the heads done and putting adifferent timing system in (all myself) was a challange. not 6 months later caf started acting funny. its started acting like it was starving for fuel. so i replaced fuel pump (driverside) replaced fuel sending unit on leftside. fuses and relays i have replaced valve covers i put MSD coils in new spark plugs cyoles timing system PCM repalced but the car still starts up after about 5-10 sec boggs down sputters reves back up and boggs down a dies. everthing on this engine is less than 6 months old including pcm. the only thing that i have not replaced is the intake and throttlebody. i also had a peddle commander installed but removed. spark plugs look like they nare burnt im getting no codes my MS906BT scanner says that cams are in sync ive done everything i can think of.
any help would be great here are some read outs i have thanks in advance for any suggestions
File Type: pdf
File Type: pdf
File Type: pdf
