Sponsored by:
Sponsored by: CARiD
O2 sensor splice
Old Jul 4, 2022 | 09:19 AM
Blueball's Avatar
Blueball
Default O2 sensor splice
I have a 5.7L '06 charger and I need to replace a cat converter but I don't want to spend the money. Can I splice the downstream O2 sensor wires together from left and right catalytic converters to trick the computer? Or do I have to weld an additional O2 sensor mount into the good cat?
I am in Ontario where there is no emission inspections.
Old Jul 4, 2022 | 10:24 AM
Aren't there direct-fit replacements available in the aftermarket??
Old Jul 4, 2022 | 10:35 AM
Blueball's Avatar
Blueball
Aftermarket replacements are $500 Cdn right now and almost impossible to find in short time and I don't need cats at all. I just don't want the check engine light on all the time.
Old Jul 4, 2022 | 01:20 PM
Weld in another bung then. They are cheap and easy.
Old Jul 5, 2022 | 01:51 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Sure you can, but not if you want it to run right LMAO......get a set of catless mids and turn the rear O2 sensors off in the tune.
