Sponsored by:
Sponsored by: CARiD
Can’t be the hub bearing….
Old Dec 13, 2022 | 02:56 PM
BogeysBest330's Avatar
BogeysBest330
Default Can’t be the hub bearing….
2014 Dodge Charger R/T
I was having a wobble and a lot of play in the steering especially on the freeway, which seems to be on the passenger side. I replace the rear hub, and still had the problem. Over the past weekend I replaced the front thinking it was surely the problem. The car now runs smoother but the rattle/wobble has gotten worse. It almost feels as if my lugs nuts are loose and the wheel might rattle off. So what else could possibly be wrong or what’s my next move???
Old Dec 13, 2022 | 04:02 PM
dodgetruck2's Avatar
dodgetruck2
If you're feeling the vibration/wobble in the steering wheel its most likely an issue on the front side, try rotating tires, or have the tires balanced. Could be a broken cord in the tire, or out of balance. Make sure all busings, tie rods, struts, ect are tight, could be a back strut, does the car sit goofy or ride different
