Sponsored by:
Sponsored by: CARiD
07 Charger RT STALLING, RUNNING RICH
Old Feb 19, 2023 | 08:29 AM
jyankauskas1's Avatar
jyankauskas1
Default 07 Charger RT STALLING, RUNNING RICH
Hi everyone new to working on dodge vehicles especially cars but have alot of auto experience looking for help on this one heres whats going on,
07 rt 5.7 cant keep it runnng stalls out if i let off the gas and dumping fuel when is runing it seems codes are
-p03000 ran mis
-P0113Intake air temp
-P0058 Heater control bank2 sensor 2
I have a very metallicy slime on the inner part of my throttle body
large amounts of unburned fuel when i keep it running by 40 percent throttle atleast
here are my readings at time of p0300
FUELSYST1- OL
FUELSYS2- OL
LOADPCT 37.6 PER
ETC 64 DEGREES
SHRTFT1 0.0
LONGFT 0.0
SHRTF2 0.0
LONGFT2 0.0
MAP 12.6 INHG
RPM 706
VSS 0MPH
SPARKADV 28
IAT -40
TP 29 PERCENT
RUNTIME 29SEC
EGR PCT 0.0
EGR ERR 0.0
EVAP_PCT 0.0
FLI 65.9
BARO 29.2
VPWR 13.8
LOAD ABS 33
EQ_RAT 0.961
TP_R 10.6
AAT 54
TP_B 21.6
APP_D 25.5
APP_E 12.5
TAC _PCT 10.6
Old Feb 19, 2023 | 10:07 AM
IAT reading -40 is gonna be a problem. So far as the PCM thinks, it is REALLY FRIGGIN' COLD, therefore, it has to add fuel to get a burnable mixture. Fix that first, clear codes, see how it runs.
Old Feb 19, 2023 | 03:17 PM
jyankauskas1
Okay new iat sensors in still same issue
Old Feb 19, 2023 | 08:50 PM
Is it still reading -40?
Old Feb 20, 2023 | 12:18 AM
jyankauskas1
no it’s reading proper temperature now
Old Feb 20, 2023 | 09:55 AM
Your fuel trims are all zero though.... Is the engine misfiring? Was that freeze frame taken at idle? Throttle by wire? Or is there an actual cable?
Old Feb 20, 2023 | 07:01 PM
SHO Rod's Avatar
SHO Rod
Also, do you have a means of testing the fuel rail pressure so you can see how quickly it bleeds down after shutting the vehicle off? I too am confuzzled by the 0.0 fuel trim values. That really doesn't make sense, unless maybe the readings you provided were immediately after clearing the diagnostic codes.
-Rod
