Sponsored by:
Sponsored by: CARiD
Lock problem
Old Jul 22, 2023 | 12:22 PM
Ghostdog38side's Avatar
Ghostdog38side
Default Lock problem
hello, the dodge charger does not lock anymore. yet the indicators flash as if it is locked. but nothing else happens. can you help me ? dodge charger 5.7 2016 .
Old Jul 23, 2023 | 09:12 AM
SHO Rod's Avatar
SHO Rod
Do the locks work using the buttons on the window switch, just not from the fobs, or do those buttons not work either? Does the trunk release work from the keyfob? And please confirm this is the factory installed remote keyless entry versus an aftermarket alarm / keyless system.
-Rod
Old Jul 28, 2023 | 01:39 PM
Ghostdog38side
-Rod
Its not a keyfob problème . They work perfectly . Its a Factory installed remonte keyless
I have change thé driver door module but same problèm. I have thé error code b224f
Old Jul 28, 2023 | 01:40 PM
Ghostdog38side
Who Can help me ?
Old Jul 28, 2023 | 05:17 PM
Verify the wiring that goes from the body, into the door. The wires in the tube between body and door flex a lot, and like to break.
