Sponsored by:
Sponsored by: CARiD
Weird non-squared edges on oil pan drain plug nut
Old Apr 6, 2024 | 02:42 PM
BaronVonJ's Avatar
BaronVonJ
Default Weird non-squared edges on oil pan drain plug nut
I was getting started to change my oil, and the plug just would not loosen. The last change was done at a shop, so I figured they must have just over-tightened it so I got out my torque wrench. Then my socket cracked. I couldn't really see the nut from where I was so I took some pictures, and the darn thing doesn't have actually squared off edges. Mind you, I don't mean they're rounded from wear. It's like it's been welded/soldered or something. Any ideas why it's like this or the best way for me to deal with it?
Old Apr 6, 2024 | 03:01 PM
Replace that one. Have the new one in hand, and use vice grips to get that one out if you have to.
Old Apr 6, 2024 | 04:02 PM
BaronVonJ's Avatar
BaronVonJ
Kinda what I figured, just wanted to check myself before doing something stupid.
Old Apr 6, 2024 | 11:42 PM
SHO Rod's Avatar
SHO Rod
That's pretty typical of a drain plug that has had a wrench slip, either because it was not the correct size or it was not on completely and straight, or some combination of all that. It could be due to the cracked socket. It's not due to someone having welded or soldered on it. When you get the new drain plug, make sure the wrench/socket you plan to use fits properly before installing the plug. Hint: The correct socket/wrench is mostly likely metric rather than SAE.
-Rod
Old Apr 8, 2024 | 10:22 AM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Some d!ckhead used an adjustable wrench on that way too many times. A proper good one is a perfect 13mm.
