Sponsored by:
Sponsored by: CARiD
2009 SXT Integrated Power Module wiring diagram
Old Apr 21, 2024 | 05:27 PM
69rt440's Avatar
69rt440
Default 2009 SXT Integrated Power Module wiring diagram
Does anyone have a wiring diagram for the 2009 Dodge Charger SXT Integrated Power Module, P04692270AH? This part number has been superseded by P04692270AJ which has additional fuse and relay positions. The AH version has no relay for the AC clutch while the AJ does. My Charger is low enough on freon that ac clutch won't engage, since there is no relay on the AH version how can I manually engage the ac clutch?
Old Apr 21, 2024 | 06:37 PM
Should be a dark blue/yellow wire on the compressor clutch connector, that's the power feed, other side is ground. Apply 12 volts there, and the clutch should engage.
Question becomes, why do you want to manually engage the compressor? If you are going to recharge the system, just start adding refrigerant, the compressor will start when pressure comes up enough.
