Sponsored by:
Sponsored by: CARiD
2009 charger
Old Jul 9, 2024 | 03:56 PM
Amidalhisnawi's Avatar
Amidalhisnawi
New Member
Default 2009 charger
Hey I have a 2009 charger 3.5 and the ac just stopped working while I was idling, the ac lines get cold, it has the exact pressure it’s supposed to read at ac clutch engages but it’s not cold what could be the issue?
Old Jul 9, 2024 | 04:11 PM
Is it just blowing warm air??
Old Jul 10, 2024 | 06:54 PM
SHO Rod's Avatar
SHO Rod
If the clutch is remaining engaged and the low pressure line is getting cold it doesn't sound like the A/C stopped working. It sounds more like either an airflow issue or blend door issue. Are you getting air flow out the vents? Is the radiator fan pulling air through the condenser and radiator? Have you checked your cabin air filter?
-Rod
