Sponsored by:
Sponsored by: CARiD
2015 Charger SXT Fuel Gauge Stuck
Old Sep 2, 2024 | 09:09 PM
Jstarr78277's Avatar
Jstarr78277
Default 2015 Charger SXT Fuel Gauge Stuck
My 2015 Charger SXT fuel gauge is stuck at 3/4. I filled up yesterday and the needle did not move, the miles left to empty reading is also off and not showing correctly. Any help???
Old Sep 3, 2024 | 08:47 AM
Does the gauge test properly at startup? Does it always return to the same position? Might be a stuck float in the tank....
Old Sep 3, 2024 | 11:29 AM
Jstarr78277
When I start the car the gauges all reset like normal. The needle then returns to the 3/4 position and stays there, however the range on the miles left to empty continue to drop.
Old Sep 4, 2024 | 09:31 AM
That's just odd..... Hard tellin' if that's a gauge problem, or a sending unit problem..... If the gauge tests properly though, that tends to indicate a sending problem.
