Sticky valve or failing rocker arm?
Neither rocker nor pushrod nor valve are trying to move and the engine isn't screeching. Failed lifter and/or that cam lobe is completely worn down. It's not an MDS cylinder so it's not a solenoid.
It's not a SBC, cam is under the vee like an LS. Only view you'll get is the intake ports and the MDS solenoids.
